Running package 2.0.0~rc3+nolibs-1~daily~ubuntu12.04.1 from PPA on Ubuntu 12.04.
In searching for any existing threads on this topic, I was not able to find any. Whenever I attempt to save a block, LibreCAD crashes. I click the disk icon in the Block List. File requester pops up. I choose the location and name. Click "Save". Immediate Seg fault. A file *is* written containing the following two lines. 999 dxfrw 0.5.10 I ran librecad once with the --debug option. Here are the last few lines of the debug file: Setting active pen... QC_MDIWindow::slotPenChanged() begin QC_MDIWindow::slotPenChanged() end QC_ApplicationWindow::slotPenChanged() end RVT_PORT emit windowsChanged(true); QC_ApplicationWindow::slotWindowActivated end QG_GraphicView::paintEvent begin QG_GraphicView::paintEvent end QC_ApplicationWindow::slotWindowActivated begin RS_Graphic::saveAs: Entering... RS_Graphic::save: Entering... RS_Graphic::save: File: /tmp/test.dxf RS_Graphic::save: Format: 2 RS_Graphic::save: Export... RS_FileIO::fileExport Setting up LFF filter... RS_FilterDXFRW::RS_FilterDXFRW() RS_FilterDXFRW::RS_FilterDXFRW(): OK RS_FilterDXFDW::fileExport: exporting file '/tmp/test.dxf'... RS_FilterDXFDW::fileExport: file type '2' I'm happy to do whatever I can in gathering more debugging data to assist in troubleshooting. |
Oops. I see that I may have posted this to the wrong area. Can an admin move this to the appropriate area? Or should I re-post there?
My apologies. |
In reply to this post by DanFreeman
this bug was fixed after 2.0.0, and will be in 2.0.1.
Can you build and verify this bug is fixed? To build on ubuntu from the newest git source: http://librecad.org/cms/home/from-source/linux.html
I tried. Make failed. These were the steps I took: - copied/pasted the apt-get line from the page you referenced to install all the packages necessary for the build environment - coped/pasted the git line for downloading a local copy from the repository - cd into LibreCAD dir - qmake librecad.pro - make This was the result: cd libraries/ && make -f Makefile make[1]: Entering directory `/usr/local/src/LibreCAD/libraries' cd libdxfrw/ && make -f Makefile make[2]: Entering directory `/usr/local/src/LibreCAD/libraries/libdxfrw' g++ -c -m64 -pipe -std=c++11 -g -O2 -Wall -W -fPIC -D_REENTRANT -DQT_WEBKIT -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++-64 -I. -I/usr/include/qt4/QtSvg -I/usr/include/qt4 -I../../generated/lib/libdxfrw/moc -o ../../generated/lib/libdxfrw/obj/libdxfrw.o src/libdxfrw.cpp cc1plus: error: unrecognized command line option ‘-std=c++11’ make[2]: *** [../../generated/lib/libdxfrw/obj/libdxfrw.o] Error 1 make[2]: Leaving directory `/usr/local/src/LibreCAD/libraries/libdxfrw' make[1]: *** [sub-libdxfrw-make_default] Error 2 make[1]: Leaving directory `/usr/local/src/LibreCAD/libraries' make: *** [sub-libraries-make_default-ordered] Error 2 |
First, it should be:
qmake -r to run qmake recursively into subdirectories. I realize your ubuntu is probably too old for std=c++11. can you run: sed -i'' -e 's/c++11/c++0x/g' common.pri to use std=c++0x, and run "qmake -r" again, followed by "make"
