Creating Drawing TEMPLATES
Buzzscorpion
Hi folks, Tony here used to use Bentley and, fleetingly, Autosketch. Problem I have is this How do you Create a Drawing Template that you can open at will, draw upon and save so that you get a matched set of drawings when you are finished ?  HELP PLEASE
Re: Creating Drawing TEMPLATES
Simply set up an empty drawing with size, scale , border etc to your liking and save it let's say as 'template.dxf' at any place. When you want to start a new drawing with the same settings then open 'template.dxf', save it again as (Save as...) maybe 'drawing1', and make your drawing on it, and save it again in the end. You could also do the 'save as ... drawing1' after finishing drawing on the template, but there is a risk of accidentally losing it.
