Cutting up an ellipse
Isegrimm_666
Hello ...
I am currently despairing over a step that I absolutely cannot manage:
I am drawing - in an isometric illustration - as part of a room view a round table with a round base plate, connected by a center column.
Both ellipses are finished, as is the center column. However, the stand would cover a rear part of the ellipse. That's why I'm trying to cut out the small piece of the ellipse of the base plate that is covered by the stand (see picture).
Translated with DeepL.com (free version)
It doesn't work.
I have tried with “Trim”, with “Divide” ... nothing works.
How can I implement this?
Re: Cutting up an ellipse
Could you upload a minimum dxf with the issue?
Both trim/divide should work for ellipse+line.
Isegrimm_666 wrote
Hello ...
It doesn't work.
Isegrimm_666
Hi dxli ...
I was then able to solve it with a trick solution:
Where the ellipse of the stand intersects the table tube, I drew a line through both intersection points and used this line as a “knife” for trimming.
The lines of the table leg did not work as a “knife”, as it was not the part between the lines that was trimmed away, but half the ellipse.
But thanks for your help.
