DWG support
Fra
DWG support
Fra
Hello everybody.
I'm a Mechanicall engineer and I'm starting to work in Linux.
I need to make 2D drawings (for home applications), so I decided to start to use LibreCAD (I'm using 2.2.0 alpha version).
Unfortunately there isn't *.dwg file support. I tried to open a simple *.dwg file (designed with AutoCAD 2008), but it doesen't work...
So I decided to investigate and I found a method:
I used teigha converter: i converted the file from *.dwg to *.dxf and it was possible to open the file with LibreCAD!
I saw that is possible to convert from *.dxf to *.dwg.
Searching on internet, it seem that it is possible to use TeighaFileConverter directly from the linux shell, so could be an idea to integrate this function inside LibreCAD?
Regards
Re: DWG support
AKmatiAK
It would be nice to support .DWG natively in LibreCAD
Re: DWG support
LibreCAD already has DWG support. But the problem is, that DWG support is very rudimentary. DWG is a closed format and all available documentation is from re-engineering. Thus there are still often issues opening DWG files.
