Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on Mar 22, 2012; 9:59pm.
When importing LibreCAD dxf file into FreeCAD, the resulting lines are arcs do not resemble the original drawing. It was just a bunch of random lines. However, I am able to open FreeCAD dxf with LibreCAD. I'm running V1.0.1 on Debian Squeeze. thanks, John ps. Originally, I also asked about if there is a way to convert between metric and english units. The dxf file exported from FreeCAD are in millimete. I found answer. I just scale the entire drawing by whatever conversion factor I need. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
lines in LibreCAD end up being arcs in FreeCAD. Is that the bug behavior?
If so, please report a bug to our sourceforge bug tracker. Please attach a dxf file to show this bug. Thanks! dxli |
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
1 post
In reply to this post by tux-lab
hello tux-lab,
running last stable FreeCad on WinXP and LibreCAd 1.0.1 aswell, drawing this: http://www.2shared.com/file/4cYqZHQC/Profil1.html in Librecad, save as dxf, open it with FreeCAD, work abs. perfect. Even operations as upgrade and following extrude will work with no problem at all. I will test tonight on my Kubuntu 10.10 , and report tomorrow. But in the last 4 month i did majorly my 2D Sketch in LibreCAD and then got them into FreeCAD to make solids, with no prob. at all. Please provide versions of both programms. Best regards newbee1 |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I don't know if the problem i am having is a software bug or an operator error. Anyway, attached is a screen of what the dxf looks like under LibreCAD and when imported into FreeCAD.
I did a few tests and I noticed that regular lines and arc show up fine during FreeCAD import. However, the tangent and trimmed intersections shows up as disjointed when imported into FreeCAD. I just did a quick test with Inkscape import and that works fine. . . . so maybe the problem is with FreeCAD import? Attached are, 1)screenshots of the original bottle opener dxf as drawn in LibreCAD and improted dxf under FreeCAD 2)screenshots of tangent and trim intersections as drawn in LibreCAD and as improted into FreeCAD 3)the bottleopener dxf as drawn using LibreCAD ![]() ![]() bottle opener dxf file |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
In reply to this post by newbee1
Hello newbee1
How do you import from LibreCAD into FreeCAD for extrusion? I can import the dxf but I can't turn it into a sketch for extrusion. The imported entity is listed as an object instead of a sketch. thanks, John |
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
1 post
Hy John(tux-lab),
after you imported the drawing into Freecad, you will have to start at one point of convinience, click one line element, and follow the sequence around as if you follow a circle. Clockwise or the other way around, does not matter. ONLY important is, that u click the single line elements,; even the smallest ones; in the sequence as if it is one non-interupted line. After that u need to click once on the ARROW for upgrade, so will be assembled as one line entity inside Freecad. Is it done, u will se the appearance of an new Element in the left side Entity-tree-view. NOW u NEED to click exactly on that entity, IN THE TREE-View, and then on the EXTRUDE-Icon next to the upgrade ARROW in the TOOL-Bar. Another way could be to do the selection and operation via Python, but i am far from knowing how to do that. If you are interested, i may give it a try, if u have a chnace to upload your dxf somewhere, and post the LINK. So then i can give you more feedback. Hope i could help in som way, best wishes, regards newbee1 P.S. Almost forgot, u shell select PART- or PART-Design Workbench to get needed Icons for upgrade and extrude in the toolbar. |
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
1 post
This post was updated on Mar 26, 2012; 11:33am.
UUPPSS,
sorry John, didn´t see you had included the link for the dxf. As i load it into my FC version 0.12 5284 it loads perfect as drawn in LibreCAD. Then i am getting in trouble about the upgrade and extrude features. So it seems, that you are running an experimental version of FC, maybe some of the 0.13 Versions ? Anyway, i think u should post your request into the FreeCAd forum. Normaly wmaier or yorikvanhavre have the right answers for you. And you should use "Complete" Workbench, to have all functions at hand. regards, newbee1 |
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
1 post
Hello John,
did you get any usefull asssistance at the FreeCAD-Forum? |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I still don't know if the problem is with FreeCAD or LibreCAD. . . anyway, I'll look into it again when I tackle the next project. I'm almost done with the current one. I used FreeCAD for the 3d design, but the subsequent dimensioning for machining coordinates where all done under LibreCAD. I had to search for a work around for copying between layer which was something I had to do often.
This bottle opener was made entirely with open source software. ![]() ![]() |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
wonderful project!
It helps to submit a dxf file for us to investigate. You don't have to be worried about your data, because you can make some random drawing to show the problem. I can see there's a great need for combination of FreeCAD and LibreCAD. Hopefully, a new plugin interface of LibreCAD and some help from the FreeCAD community will make it work better. |
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
1 post
Hello John,
the opener looks realy great ! In the meantime i did some testing on my Kubuntu 11.04 myself, as where i am also using the 0.13-dayly version of Freecad. Over there i get the same weird stuff, as you stated in the begining of the thread. But as mentioned earlier, running both under existing Win***XP, with the mentioned versions of software, the outcome is absolutely correct. So in my opinion, there is somthing wrong in the interpreting of those DXF-Files under ubuntu. This makes me feel, that there troubles in Library´s in the system, else it should be as mixed in Wind***, as under ubuntu. Best regards, newbee1 p.s.: @dxli: as far as i remeber, in the first thread WITH pictures, i have found a link with the dxf-file. Is it still there ? |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
tux-lab:
Your file https://docs.google.com/open?id=0B1EDmDJJM3_LTUFZX3dUWmVSMnlkd1BZcVV1MVBxZw are correctly shown in google docs opening it with LibreCAD 1.0.1 and 2.0.0 alpha (new read library) works opening with inkscape works opening with blender 2.6.1 works opening with AutoCAD works opening with gvSIG works FreeCAD not installed, then not tested. All test are made in openSUSE 11.4 x86_64 |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
tux-lab:
I talk with Yorik from FreeCAD and there is no a compatibility issue In FreeCAD Menu "Tools->Edit parameters" in "Preferences->Mod->Draft" add a "new integer item" called "precision" & value 12 (p.e.) and WORKS |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Wow, that did the trick. I am able to import the dxf file without any problems now. A big thanks! |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I completed the first batch of bottle openers. I am still working on documenting the process, but if any of the LibreCAD developers, or anyone you think contributed to LibreCAD and would like a bottle opener, or anyone who replied to this thread, email me and I'll mail you one. Or drop by for a visit If you are in the Los Angeles area. The size is relatively small, ~ 4" x .5" x .1", machined from 304ss, then tumbled and burnished to break the sharp corners, then electrochemically etched.
The bottle opener was drawn with FreeCAD because there are some arc to arc tangential relationships that I didn't know how to accomplish with LibreCAD. However, LibreCAD was used to layout the machining tool path and find the end points for writing g-code. I had to convert the units from inch to millimeter for drawing with FreeCAD then used LibreCAD to convert the FreeCAD dxf export back to inch. It worked quite well. The price is Free as in Freedom. While I can't buy everyone a beer and this is not exactly the best bottle opener I've used, it does get the job done and it's made with open source software in a relatively free country. As a disclaimer, The general shape of the bottle opener and the open source aspect won't change, but this is an evolving project and the cavity may be removed or modified to reduce the machining time which is currently way too long. Thanks again to LibreCAD and other open source communities that made this bottle opener project possible. thanks, John project.tuxlab@gmail.com ![]() |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
congratulations john
Soy Yo On Tue, Apr 17, 2012 at 7:11 PM, tux-lab [via LibreCAD] <[hidden email]> wrote: I completed the first batch of bottle openers. I am still working on documenting the process, but if any of the LibreCAD developers, or anyone you think contributed to LibreCAD and would like a bottle opener, or anyone who replied to this thread, email me and I'll mail you one. Or drop by for a visit If you are in the Los Angeles area. The size is relatively small, ~ 4" x .5" x .1", machined from 304ss, then tumbled and burnished to break the sharp corners, then electrochemically etched. ... [show rest of quote] |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Great work!
I'm glad to see that LibreCAD it is useful and gives encouragement to continue to improve the program I do like to have one but a shipment to Spain will cost more than beer. is better take the beer to my health :-D |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
1 post
same problems ecoutered
after I imported the drawing *.dxf made with librecad, into Freecad the profile has no continuity as in librecad flOv4.JPG flOv4x.JPG |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This is a problem of FreeCAD, no of LibreCAD.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
The precision parameter fix worked for my .dxf file as well.
Thanks Rallaz |
