-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
Files referenced (DXF and PDF) can be found on <a href="
http://forum.librecad.org/font-problems-with-DXF-import-tp5711605p5711616.html">this
 previous post</a>.
The PDF shows how AutoCAD plots the DXF. Opening in LibreCAD, you'll s
ee it produces different results.
For example, if you look at the large figure near the top, at the bott
om, the radius is shown as "R20 [R.787]" whereas LibreCAD shows it as
"20.0000," kind of far away from the arrow that indicates where that m
easurement exists.
This suggests several problems, such as the number of significant digi
ts (which I can edit on a global scale, but you'll notice that not eve
ry measurement has the same precision), the displayed units (the fact
that both metric and imperial are included), and a clear connection be
tween the measurement and what is being measured. Additionally, the di
ameter symbols are missing.
Walter Lapchynski
Information Services Assistant
Project Management Facilitator
Green Gear Cycling dba Bike Friday
800-777-0258 | +1 541-687-0487
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.22 (GNU/Linux)
iQEcBAEBCAAGBQJVegdlAAoJEC/Sz6G3AJ2T+qkIAK/YXowX74BgstjuBm/hXW7y
sV13m6hB56YLIq/CM0KltLFYIdmDsaeyduPJbt9WyS0tz+cToPwoiZNGntltsxy3
FlBVIw4m4G7/VWoO8BX0iOT6blyF0b5XoIPEydeIOZiiP6lJOx8zkYAz2jSB/sv9
LgyafnRKUQN5KtRMyJcL57l2jQRacCM+4vBWjsguS0ci9hXb+HSVSOOQg9XmHvVZ
QGIrPVol1jiddILPr5+7jVXXgv2oP0tvKul/soDt8+EBffRjaUc0bcigM0yZV1Nf
EGCKTYYz21u83RQCLhtykWL6QSUS+4HPuFuuTPVnVvb2CAQrpPxja4RYi1uYZuU=
=yK4J
-----END PGP SIGNATURE-----
