Deselecting objects
9 messages Options
Deselecting objects
brwhite1
I thought it might be nice hitting the escape button would deselect any objects that you have currently selected in a drawing.  It is kinda tedious having to go to the selection menu and click deselect everytime I screw up and select the wrong object (  I do this often :)  ).
Thanks! and keep up the great work.
Re: Deselecting objects
hey,
can you try hitting the escape twice quickly, this should de-select all objects.
Ries
On Aug 16, 2011, at 12:36 PM, brwhite1 [via LibreCAD] wrote:
http://librecad.1049103.n5.nabble.com/Deselecting-objects-tp4705275p4705275.html
brwhite1
Tried it...still no go.  Any other ideas? I'm running the linux installation on Xubuntu 10.10 if that's helpful to know.
Can you report it as a bug?
THis is how it suppose to work..
Rallaz, if you read this, can you see what happens on Linux? On master?
Ries
http://librecad.1049103.n5.nabble.com/Deselecting-objects-tp4705275p4705466.html
brwhite1
Reported it. Thanks!
This feature works. I think there since version 1.0.0RC1
Billy White:
For bugs  is very important to indicate the system and the LibreCAD version is used.
Your system is Xubuntu 10.10 but that LibreCAD version uses?
can be seen in menu "Help->About"
About selections:
When you click an object it is select, another click in the same object is deselect (not lost well selected objects)
brwhite1
Sorry, its my first bug report and I wasn't really sure what info was needed.
My LibreCAD version info...
Version: 1.0.0beta5
SVN Revision:
Date: Feb 8 2011
(c) 2010 by R. van Twisk
Re-clicking most objects does deselect them, however when I have a large number of items selected I still run into this problem unless I individually click every line in the drawing.
Thanks for the help
I think the beta1 might not have that,
but the latest PPA will have that.
Ries
Version: 1.0.0beta5
SVN Revision:
Date: Feb 8 2011
Thanks for the help
http://librecad.1049103.n5.nabble.com/Deselecting-objects-tp4705275p4712747.html
brwhite1
Got the latest PPA and it works fine now.  Thanks
