Dimension a line that is already drawn
drkirkby
I have a very simple drawing
http://www.kirkbymicrowave.co.uk/Dielectric-Test-Fixture/U-channel.dxf
of basically a U-channel, which I drew with version 2.13 on Windoze.
U channel, where I need to dimension the depth
Most of the dimension are integer multiples of 1 mm, except the depth, which should be 17.85 mm. I've dimmensioned all the lines which are multiples of 1 mm, by just picking points near the line, which is easy as the program snaps to the 1 mm grid easily enough.
But the lines which are 17.85 mm don't fall on the grid, so I can't dimension this way.
Is there any way to select a line, then add the dimension to the drawing?
Dave
Re: Dimension a line that is already drawn
drkirkby
Ignore this, unless you can think of a better way. Snapping to the intersection of two lines did the trick.
