I recently discovered this option, which was unknown to me and, according to some YouTube video tutorials, is unknown to many LibreCAD users. Until now, I've mainly used the Snake tool to draw orthogonal lines, but I recently discovered another option that, at least for me, is perfect:
When you want to draw an orthogonal line from a specific point at a specific distance, you can use the following key combination:
-If it's the first point of a line or polyline, first mark the starting point, then type the distance from the line you want to draw and press Ctrl+the arrow in the direction you want to draw.
-If you want to continue from that last point, simply repeat the last step.
I'm sure many people already knew this way of drawing orthogonal lines, but for me it was quite a discovery.
Many thanks again to the developers.
