ECAD Symbols
8 messages Options
ECAD Symbols
Kozbot
UPDATE 5/18/2017 - This library was lost some time ago before I was able to post the symbols properly.  I am now in the process of rebuilding it in case anyone sees this thread.
SEE: http://forum.librecad.org/ECAD-Symbols-Again-td5714870.html
I was about to start on an ECAD library for myself and thought that since I was already redrawing everything if I just made sure to use the right software I could release without licensing issues to other people as well since there are not many free libraries out there.  So I have a python program I am putting together that automatically generates a dxf with all of the symbols I use personally (in US so it's a hodgepodge).  Works beautifully for me and opens fine in LibreCAD 2.  Everything is drawn currently in a 10x10 unit square so 11 points by 11 points to align to.  Not going crazy with attributes or scaling yet just seeing where it goes right now.
This is for my own reference / what I plan to do next:
MISC:
-			DRAW HORIZ WIRE	[FULL WIDTH]			DONE
|			DRAW VERT WIRE [FULL HEIGHT]			DONE
/			MOVE X TO 0 AND LOWER BY ONE LINE SCALE		DONE
			MULTIPLES ex:// WILL MOVE BY THAT MANY LINES	DONE
>			MOVE OFFSET RIGHT BY ONE BLOCK (10 UNITS)	DONE
			MULTIPLES ex:>> WILL MOVE BY THAT MANY BLOCKS	DONE
<			MOVE OFFSET LEFT BY ONE BLOCK (10 UNITS)	DONE
			MULTIPLES ex:<< WILL MOVE BY THAT MANY BLOCKS	DONE
w[pf][123456789]	DRAW WIRES & WIRE JOIN AS DEFINED		DONE
	p		DRAW WIRE AS PHANTOM LINESTYLE			TODO
	f		DRAW WIRE AS FIELD LINESTYLE [TYP. DOT/GREEN]	TODO
  1-4,6-9		WILL DRAW WIRE FROM CENTER TO NUMBER PRESENT	DONE
	11..11111 etc	MULTIPLES TO EXTEND LINE (HALF BLOCK STEPS)	DONE
	5		WILL DRAW A WIRE JOIN				DONE
			7  8  9
			4--5--6
			1  2  3
CONTACTS:
NO			NORMALLY OPEN					DONE
NC			NORMALLY CLOSED					DONE
FORMC			FORM C CONTACT NO-C-NC				DONE
->'>> w22222226 - NC t.14 T^32 //// T^30 t.11 w4586 - NO t.12 T^31'
TERMINALS:
t[.#]			DEVICE LEVEL TERMINAL WIRES IN AND OUT		DONE
ti[.#]			DRAW WIRE ON INCOMING SIDE ONLY			DONE
to[.#]			DRAW WIRE ON OUTGOING SIDE ONLY			DONE
	.#		# = 1+ DIGITS TO BE DRAWN BELOW TERMINAL	DONE
T[.#][^#]		PHYSICAL TERMINAL				DONE
	.#		# = 1+ DIGITS TO BE DRAWN *INSIDE* TERMINAL	DONE
	^#		# = 1+ DIGITS TO BE DRAWN *ABOVE* TERMINAL	DONE
ACTUATED SWITCHES:
At			ACTIVE ON LOW TEMP				DONE
AT			ACTIVE ON HIGH TEMP				DONE
Ap			ACTIVE ON LOW PRESSURE				DONE
AP			ACTIVE ON HIGH PRESSURE				DONE
Al			ACTIVE ON LOW LEVEL				DONE
AL			ACTIVE ON HIGH LEVEL				DONE
Af			ACTIVE ON LOW FLOW				DONE
AF			ACTIVE ON HIGH FLOW				DONE
COMPONENTS:
CB			CIRCUIT BREAKER					DONE
CB2			CIRCUIT BREAKER 2 POLE				DONE
->'CB // CB'
CB3			CIRCUIT BREAKER 3 POLE				DONE
->'CB // CB // CB'
SOL			SOLENOID / MAGNETIC (FOR CB & MMP)		DONE
CR			COIL / RELAY					DONE
FB[#]			FUSE BLOCK [FUSE HOLDER]			DONE
	#		# POLES						DONE
FU[$][!]		FUSE						DONE
	$##.#		##.# RATING OF FUSE EX. 7.5			DONE
	!XXXX		XXXX TYPE OF FUSE EX. MIDGET			DONE
MDS			MAIN DISCONNECT SWITCH [3PH]			TODO
FDS			FUSED DISCONNECT SWITCH [3PH]			TODO
CBD			CIRCUIT BREAKER DISCONNECT [3PH]		TODO
XFMR[#.#]		TRANSFORMER					TODO
	#.#		NUMBER OF PRIMARY.SECONDARY TAPS [DEF 1.1]	TODO
GEND			GENERIC DEVICE WITH 2 TERMINALS			TODO
GENDNO			GENERIC DEVICE WITH 2 TERM AND NO CONTACT	TODO
GENDNC			GENERIC DEVICE WITH 2 TERM AND NC CONTACT	TODO
MOTOR RELATED:
MTR			THREE PHASE MOTOR				TODO
MTR1			SINGLE PHASE MOTOR				MAYBE
MINT			MECHANICAL INTERLOCK				TODO
MSF			FORWARD MOTOR STARTER				TODO
MSR			REVERSE MOTOR STARTER				TODO
MSC			THIRD STARTER REQD FOR SINGLE PHASE REV.	MAYBE
REVKIT			3PH REVERSING WIRING				TODO
OL			THERMAL OVERLOAD				DONE
MMP			MANUAL MOTOR PROTECTOR				DONE
->'CB SOL t OL t // CB SOL t OL t // CB SOL t OL t'
PILOT DEVICES:
PBO			PUSHBUTTON NO					DONE
PBC			PUSHBUTTON NC					DONE
ES			E-STOP/MUSHROOM PB				DONE
PL			PILOT LIGHT					DONE
PTTL			PUSH TO TEST PILOT LIGHT			DONE
->'PBC << w2 > - w4562 - PL - / > w82 >> w82 / PBO  - w48'
SS2			2 POS SELECTOR X - X MAINTAINED			TODO
SS2L			2 POS SELECTOR X -> X SPRING RET. FROM LEFT	TODO
SS2R			2 POS SELECTOR X <- X SPRING RET. FROM RIGHT	TODO
SS3			3 POS SELECTOR X - X - X MAINTAINED		TODO
SS3L			3 POS SS    X -> X - X SPRING RET. FROM LEFT	TODO
SS3C			3 POS SS    X -> X <- X SPRING RET. TO CENTER	TODO
SS3R			3 POS SS    X - X <- X SPRING RET. FROM RIGHT	TODO
-Kozbot
Re: ECAD Symbols
Kozbot
I rewrote some of the code in order to generate individual files and dump them all into an ecad sub directory of my part library.  Do I need any special permissions to eventually upload this to the wiki?
Re: ECAD Symbols
In reply to this post by Kozbot
Re: ECAD Symbols
looks like it's more suitable to add your parts to our Resources repository:
https://github.com/LibreCAD/Resources
Re: ECAD Symbols
Kozbot
What would be the correct folder structure to put the dxf files in?  Going off of what I see there guessing something similar to: /parts/kozbot/<files> ?  I was planning to eventually release the python program under MIT license ,  is that more appropriate for the blocks as well or the CC by listed in the github page for resources?
Re: ECAD Symbols
If they are intended as blocks, then blocks/kozbot/<files>
MIT is correct for code; use CC for non-code (DXF since you wouldn't add a license header).
Re: ECAD Symbols
Kozbot
Few more symbols done and Push-To-Test Light made using string code rather than manually coding the lines (wanted to see if I could actually do it using mnemonics).
Re: ECAD Symbols
Kozbot
Up to 28 Blocks now :)
