Edit rectangle bottom left corner?
Holzwurm
I created a rectangle using the 2-point rectangle function. I can edit all the corners but not the bottom left corner. Rounding and trimming don't work. What am I doing wrong?
Thanks
Hans
Re: Edit rectangle bottom left corner?
sand1024
hmm... that's quite a weird behavior indeed...
What version of LC do you use?
May you share the the DXF with such issue?
P.S
1) btw - what do you mean by "edit corner"? Move the point or apply commands to 2 lines that are near to the corner?
2) Are you sure that these lines near the corner are lines, not a polyline?
Holzwurm
here is the dxf file. I use V2.2.1.2.AbrundTest.dxf
Holzwurm
When I create the rectangle with 4 lines, i can edit all 4 corners.
