		The answer to this question must be so obvious I am looking past it!
  I want to draw an object with outside dimensions about 1500 mm by 2400 mm.
 The Y range on the Libre CAD drawing screen seems to be from about 300 to -200.
 Nothing I tried changes that significantly, even trying a paper size of A0 or larger.
 So how does one enter the numbers representing the object's dimensions (for example,
 a line that is 2215 units long)?
 Naturally, one could `scale' the real dimension (with a calculator) by say a factor of 8 and use scaled dimensions to draw the object.
 I cannot believe that is not already managed by the software - but how?
