Error message during the loading
3 messages Options Options
librazon
I'm getting an error message when I start LibreCAD.
Output from the terminal:
Cannot open DXF file '/home/<home>/.config/LibreCAD/'.
Thank you in advance.
Re: Error message during the loading
aman
First, LibreCAD is not the best option dealing with DFX files, from the FAQ:The DXF import process failed, why?
LibreCAD does not support all features of Autodesk DXF format. Currently, only the following DXF formats are supported: R12, R14, 2000, 2004 and 2007. If you have issues to import some DXF files, please report them on the LibreCAD forum.
Second, your line is odd, why second home?
Remove LibreCAD, and /home/.config/LibreCAD, and install LibreCAD again.
librazon
Thank you. It works!
