Error printing A3 paper format
10 messages Options
mickele
On my system (archlinux x86_64, LANG set to it_IT.utf8), if I choose a paper format different from A4, preview is right, but if I print on PDF, LibreCAD prints on A4 format.
Do you have any idea about possible causes?
Re: Error printing A3 paper format
In reply to this post by mickele
mickele
Thanks for your help.
I updated librecad from git, but I still have the same problem.
Also if I print on file, drawing is cut to A4 format.
mickele
mickele
Problem seems caused by Qt.
Method QPrinter::setPaperSize() doesn't work when printing on PDF (see qprinter.cpp).
Quite strange...
mickele
mickele
Yes, you're right.
However the problem is in Qt. I wrote a simple program that prints a word on an A3 paper.
On other system (e.g. windows) everything works fine, on my archlinux 64 bit it creates an A4.
Here's some code:
    QPrinter * printer = new QPrinter();
    printer->setPaperSize( QPrinter::A3 );
    qWarning("before: %d", printer->paperSize() );
    // it prints 8, the right value
    if( printer->isValid() ){
        QPrintDialog * dialog = new QPrintDialog( printer, this );
        // I set pdf as printer, but I don't change the paper size
        if( dialog->exec() == QDialog::Accepted ){
            qWarning("after: %d", printer->paperSize() );
            // it prints 0, A4 format
            QTextDocument doc;
            doc.setPlainText( trUtf8("bye") );
            doc.print( printer );
    delete printer;
This can be a bug in qt-4.7.3 or a bug in qt package available on archlinux.
maqifrnswa
On Mon, Jun 27, 2011 at 4:35 PM, mickele [via LibreCAD]
<[hidden email]> wrote:
> Yes, you're right.
> an A3 paper.
> it creates an A4.
I think you're right, it's a qt bug - don't know how much we can do with that:
http://www.eaglecentral.ca/forums/index.php?t=msg&goto=132446&S=576ba10e86783cc00e88495196dc6082
I can't find a reference in qt's bugs, however . . .
