European portuguese translation
7 messages Options
forave
First of all great job on this project.
Forave is a professional school in Portugal and we'd like to help this project by completing the european portuguese translation.
The actual portuguese translation is mostly brazilian portuguese.
How can we start the european portuguese translation?
Thanks and keep on the good job.
António Mendes
Forave - Associação para a Educação Profissional do Vale do Ave
www.forave.pt
Re: European portuguese translation
Hi António,
Sounds great.
You can start here,
http://translate.librecad.org/
Since we are still actively developing the master branch (targeting 2.0.0 version). I suppose there are always new things to translate.
Thanks,
Dongxu
On Wed, Nov 16, 2011 at 7:24 AM, forave [via LibreCAD] <[hidden email]> wrote:
António Mendes
www.forave.pt
http://librecad.1049103.n5.nabble.com/European-portuguese-translation-tp4997538p4997538.html
Dongxu Li, Ph.D.
Ed
Ed
Hi
First of all, I'd like to thank you all for doing such a good work!
I would like to help with translation in ROmanian,
but I can't find Romanian in http://translate.librecad.org/
Can you add Romanian language?
If not, what is the... procedure for translation?
My email is
eduard.pintilie@gmail.com
Thank you.
Have a great day.
ed
Hi Ed,
I think you can register at http://translate.librecad.org/, then, we add permissions for Romanian to your account.
Regards,
Dongxu
On Fri, Jun 1, 2012 at 7:03 AM, Ed [via LibreCAD] <[hidden email]> wrote:
Hi
My email is
[hidden email]
Thank you.
Have a great day.
ed
http://forum.librecad.org/European-portuguese-translation-tp4997538p5706720.html
Dongxu Li, Ph.D.
www.librecad.org
In reply to this post by Ed
Vicent Fornés
Hello Ries.
I've signed up in http://translate.librecad.org, but following your instructions (for the Romanian translator) I made the Catalan translation from the file librecad_en.ts I downloaded from the code repository.
I've tested it for the latest version 2.0.0alpha3 (Aug 12 2012) and I found some strings in the program that aren't in the file librecad_en.ts; so they are shown in English. Is there a newer version of librecad_en.ts?
How can I give you the file librecad_ca.ts I made with Qt Linguist?
