Export image positioning
3 messages Options Options
Senya
Hello.
I'm trying to export image from librecad drawing. Drawing is at zero boundary at the bottom, so square block is starting on zero coordinate Y. I want my image to be the same - having block at the bottom. But when i export, even with margins set to 0, my drawing get to the middle of exported image. Is there way to export image so, that my drawing would be aligned to the bottom?
1.dxf
Re: Export image positioning
cantcode
I don't know if one can do that but here is a quick and dirty solution.
just add a WHITE rectangle in the size of your paper (like A4 -> ca. 210x297)
(rectangle should start at 0;0)
edit:
well maybe just one line at the top (0;297 to 210;297) will do that
Senya
Thanks, that works.
12.07.2013 15:44, cantcode [via LibreCAD] пишет:
http://forum.librecad.org/Export-image-positioning-tp5708556p5708557.html
To unsubscribe from Export image positioning, click here.
