Let's try to draw a rectangle.
Enable orthogonal restriction.
Click somewhere to start a 2-point line.
It would be very convenient to be able to just move a mouse in a direction of a line (horizontal or vertical) and then just enter a length of a line. Just like it is made in AutoCAD. And yes, I understand that it can be done by entering "@100<90", but it's much easier to enter just "100".
And actually it can be said about all the other tools - to be able just to enter the number for needed parameter after clicking the button or invoking the command in command line. Just like it is made in "Circle -> Center,Point" command - so you click where you want a center to be and then just enter the number for a radius, great. So why in the "Circle -> Center,Radius" it is not the same? Doesn't make much sense to me.
