Feedback - drawing preferences, extension lines, Width drop down list visibility issue
andykmv
I am using 2.2.0-rc1-91
for the drawing preferences dialogue box, extension lines, Width: drop down list,
I had a circumstance where the drop down list was not wide enough to show the sizes to the right
Today I checked it and it seemed ok. has anyone else had this issue ?
Suggestion: make the box auto width or much wider so that all text is always displayed
Re: Feedback - drawing preferences, extension lines, Width drop down list visibility issue
andykmv
i grabbed an example when i selected the circle (above/behind dialogue) and opened properties to change the line style:
This seems to be OS dependent, for me on Linux the drop down is wide enough, even when I reduce the property window to a minimum size.
A workaround should be to extend the property window, then the drop down box should become wider too.
There is a similar issue on 4k displays. The higher DPI on 4k displays messes up many GUI elements.
We already have some open issues on Github for this and I assume that your issue will be solved with that revamp too.
andykmv
it does not occur often or consistently so far - i have not used it heavily enough see if it is consistently occurring.
i'll see if i can pin down how to repeat the issue.
