Fillet appears to work, sometimes, only on rectangles.
timlange3
Hi, I using Windows 11, LibreCAD 2.2.0.  If I draw a rectangle of 20 x 20 and then do a fillet with radius 5 it takes up to a half dozen left clicks to select the first line, same for the second.  This is after putting the crosshair directly on the line.
Drawing a two segment line and then doing fillet, I can never get a line selected.
In both cases there is only one entity in the drawing, just created a new file, then drew the entity.
How do I reliably select a line for fillet?
Tim.
Re: Fillet appears to work, sometimes, only on rectangles.
timlange3
I was able to fix the issue!  Someone else had problems just doing plain selects, could not do it.  They did a clear on all settings and it fixed the issue.  I cleared all my settings and it fixed my selection issue too!  Is there a setting that determines how close the pointer has to be to an entity to select it?
Thanks, Tim.
