First use of LibreCad
13 messages Options Options
jefken
LibreCad is a wonderful free CAD program that I quickly mastered.
I had some experience with Autocad, but it took some time to penetrate the secrets of LibreCad.
I have planned my apartment and I want to share the files to show that the use of LibreCad is not that difficult.
https://jefken153.stackstorage.com/s/H6hBxgui5yALrAU
https://jefken153.stackstorage.com/s/O3hrBjakMfQQsbM
jefken
gepensioneerd ingenieur
Gent België
LibreCad 2.2.0 rc1 Windows
Re: First use of LibreCad
Well done! But it's not finished yet. We are awaiting your drawings featuring all the bells and whistles, like dimensions, elevations with shadows and so on what is needed to make nice looking plans.
Why don't you upload your files here on the forum? Or insert an image of the plan, from a screenshot or a pdf from Print Preview. It's a good thing to have more samples of work done with LibreCAD here.
jefken
It is only the beginning...,
Gent België
jefken
I have added dimension, but are there different settings for that?
I hereby give three screenshots
two of my dimensions and one of my institutions.
Can someone tell me what the correct settings are for the dimension?
[img]https://i.imgur.com/E3v7sk1.jpg[/img]
fig 1
[img]https://i.imgur.com/C246KCd.jpg[/img]
fig 2
better visible
[img]https://i.imgur.com/wn4Ki0Q.jpg[/img]
fig 3
Gent België
jefken
What do  you mean with "elevations with shadows and so on what is needed to make nice looking plans"
How do I make elevations with shadows
Gent België
In reply to this post by jefken
There is nothing wrong with your dimensions, if you like them this way. Just extension lines "Offset" and "Enlarge" are way too small, not visible.
You could use the"General Scale" setting according to your intended scale, probably 1:50. So type in "50". Then the sizes of all elements of the dimension will be enlarged automatically 50 times (hidden), as they will be scaled down again in the printing process. This way you don't have to recalculate and change these values if you decide to rearrange and print the the drawing in a different scale,  just change the "General Scale". The individual sizes like "Text Height" then have to be typed in in the real size on paper. So in your case a 3 mm size letter would be 0.003 m.
You also could use Extension lines "Fixed length", as is the use for architecture (at least in Germany).
In LibreCAD 2.1.3 "Fixed length" did not submit to "General Scale", in 2.2 RC it does. But unfortunately the input box was not changed and allows only two digits after the decimal point. So in your case the smallest possible value 0.01 m results with "General Scale" in 10 mm on paper, which is too long in most cases. So you can either not use "General Scale" or not use "Fixed length" or accept the 10 mm length.
If you do not want that lifted small 5 as half centimeter (German standard, in Belgium too?), you must not use Format units - Linear units: "Architectural (metric)", just Decimal instead.
The shadows in an elevation (side view) you have to draw manually with a solid grey hatch.
This is an example from Claudio Guarnieri's tutorial http://forum.librecad.org/file/n5708464/tutorial_-_let's_draw_a_little_house_project.zip It is a bit outdated, as the user interface and the possibilities have changed / improved, but still worth to have a look at.
If you have a coloured facade drawing, it's more difficult. As we don't have transparent fillings to use as an overlay for shadow, we might use a normal hatch. Thin lines or maybe points.
Yuryi
1 post
Здравствуйте! Хочу освоить LibreCAD.
С кем и где можно пообщаться на эту тему на русском языке.
Заранее благодарен.
моя почта: avangard-67@yandex.ru
jefken
Привет.
Заранее спасибо, но тогда я использую Google Translate для перевода на голландский (голландский)
Gent België
jefken
exercise
Gent België
jefken
a detail
detail
Gent België
jefken
Now my settings
Gent België
I see you use blocks.
1. What are your settings under Options, Application preferences, Paths?
2. Can you share your block / Part libraries and maybe Hatch patterns?
I understand parameters are not supported so separate objects must be created for a 780 and 820 mm doors?
jefken
Hi, my settings are
the hatch patterns are those that come with the program
otherwise you can create it yourself
for doors, draw your door to scale and make a block of it and write it as dfx or copy and paste
Jef Bronselaer
Koerspleinstraat 20 bus 201
9040 GENT
België
[hidden email]
gsm +32 477 22 62 82
tel +32 9 378 57 44
url: www.jefbronselaer.net
homo sapiens non urinat in ventum...
_________________________________________
Op vr 9 aug. 2019 om 04:50 schreef flywire [via LibreCAD] <[hidden email]>:
http://forum.librecad.org/First-use-of-LibreCad-tp5717123p5717636.html
To unsubscribe from First use of LibreCad, click here.
Gent België
