For me doesn't work Circle (Center, Radius)
cheval9
Hello! Sorry, I don't speak English.
For me doesn't work Circle (Center, Radius).
I can't set the circle center.
Sometimes works if several times to press a key of a computer mouse.
LibreCad 2.0.2 version. Version for Windows. (Russian version language ).
Re: For me doesn't work Circle (Center, Radius)
Please confirm that your circle radius is not too small or too large.
set radius for circle drawing
cheval9
Everything works.  I simply didn't see radius.  I thought that at first the center should be set.  LibreCad writes that set the center.  I thought that radius should be set then.  When the center of a circle will be already chosen.
Now I understood. Radius should be specified at once too.
I wanted to make as in Autocad )
ripa
Hi
Same problem here. Three different installation's, 1x Ubuntu Gnome, 2x Win7.
Circle with center and radius don't work correctly.
You can give center point, but it never ask radius. The radius is always 1.
sp1der
Hi, you need to enter the radius in the field.
ripa
 that it can not be blind
No matter how much I tried to look, but I did not noticed. Seem to have become too much of the time used for obtaining ME10, which were fed differently.
