GUI scaling problems
ckurz7000
There's a persistent problem with scaling of several (not all) GUI elements on a 4k monitor. I'm running the latest nightly (2.2.0-rc2-7-gc819fed7) on a Win 10 laptop with a 4k monitor.
1) Even though the window controls of the main LibreCAD window appear normal, the same three controls for the drawing window are way too small to be useful.
Controls of drawing window
2) On the bottom of the LibreCAD window, there is text, which is cut off (e.g., the mouse coordinates).
Mouse coordinates
3) Many data input windows, e.g., the one for the move/copy command, are sized too small and look awkward.
Window sized too small
This distracts from an otherwise great piece of software. I wonder if something can be done to fix these scaling and display problem.
Thanks and keep up the great work!
-- Chris.
Re: GUI scaling problems
Gary S
There is a way to adjust the scaling for the application.  Refer to https://forum.librecad.org/Screen-resolution-on-with-4k-laptop-and-second-full-Hd-screen-problem-td5719542.html#a5719546  The solution offered there is for LibreCAD on Linux, but is similar for Windows.
Open a command prompt and type:
   set QT_AUTO_SCREEN_SCALE_FACTOR=1
   "C:\Program Files (x86)\LibreCAD\LibreCAD.exe"
Some before and after screen grabs:
LibreCAD without setting the variable:
After setting the variable:
