		Hello...
				How to make gear (involute) with librecad? Thanks.  |
		There's currently no native support for involute in LC.
				I'm thinking about using the new interpolation spline to create a new type of entity. Before the implementation is done for LC. You may try the equation plot plugin, as a workaround.
	 There is python script for FreeCad to
      create involute gear that can be maybe converted. But as I see in
      LibreCad there is no such features as plugin or other external
      modules.
    On 09. 09. 2014 19:48, dxli [via LibreCAD] wrote: There's currently no native support for involute in LC.  |
		there's a plugin interface, and severalplugins are included in official releases.
				actually, two official plugins can be helpful here: plot math equation, since 2.0.4 read in ascii points
				In reply to this post by eslavko
		One more question:
				What would be desirable ways to draw an involute? For example, to draw a circle, we can have many ways: 1, center and radius; 2, center and a point on the circle; 3, 3 points on the circle; 4, tangential to 3 existing circles; etc.  |
		On 10. 09. 2014 16:27, dxli [via LibreCAD] wrote:
				> One more question: > > What would be desirable ways to draw an involute? > > For example, to draw a circle, we can have many ways: > > 1, center and radius; > 2, center and a point on the circle; > 3, 3 points on the circle; > 4, tangential to 3 existing circles; > > etc. I was interestig to draw involute gear. There should be more question. Position (probably center), number of teeth, modulo (or diametral pitch & co) ... Slavko.  |
		On 10. 09. 2014 14:52, dxli [via LibreCAD] wrote:
				> there's a plugin interface, and severalplugins are included in > official releases. > > actually, two official plugins can be helpful here: > > plot math equation, since 2.0.4 > > read in ascii points > Ok I find that. But seems that for plugin I need to recompile LibreCAD. It's not some scripting language... Slavko.  |
	Right now LibreCAD 2 doesn't supports scripting. We are in process of making a newer version of LibreCAD from scratch and has support for scripting using lua. Ries has ported the python script to Lua for LibreCAD. You may see the demo here, http://skitch.rvantwisk.nl/~rvt/bmk/tmp/LibreCAD_-20140409-162814.jpg But since LibreCAD 3 is under heavy developement and read/write support for files is yet to be implemented, So at the moment if wont be available. You can even check the code for Gear at http://pastebin.com/ts3XCXqa -- Thanks Gaganjyot  |
	I was about to suggest the same thing but you were first. I think this is the best way .  |
