General Problem with LibreCAD
Jani
Hi everyone,
I am a pretty new user of LibreCAD and I am just not satisfied with the result.
As a homework I have to solve a problem with a graphical solution method. So I wanted to give LibreCAD a try. Working with LibreCAD is fine.
But there is one thing I am really sad about.  Lines, dots nearly everything is just not smooth.
Maybe I am just on the wrong way, but I was looking for a program that gives me a nice vector graphic in the end.
Lines seam to be smooth if they are horizontal or vertical, but in all other angles they are a row of squares with endless edges.
Exporting often leads to crashes and generated export files are sometimes buggy - open slowly or never!?!
I am using version 1.0 0rc1  on ubuntu 11.10.
It's a pity that the result isn't satisfying cause the software isn't bad at all.
Is there a possibility with LibreCAD to get smoother results (lines,..) ? Some options I can change? Other output methodes?
Can anybody help me with that.
I am thankful for every tip.
greetings,
jani
Re: General Problem with LibreCAD
sp1der
Hi
version 2.0.0alpha4 is available and now very recently version 2.0.0beta1.
Jani
Thx for the info.
I have a look on the newer beta version.
greetings,
jani
maqifrnswa
On Mon, Oct 29, 2012 at 8:36 AM, Jani [via LibreCAD]
<[hidden email]> wrote:
> Thx for the info.
> greetings,
> jani
To get it use the instructions here:
http://librecad.org/cms/home/installation/linux.html
and follow:
Daily Builds in Ubuntu PPA
Cheers,
Scott
Gene45
So I just started with Librecad, I downloaded 1.0.2 for windows.
Is there a newer version?
