Hi Folks!
I would do like to help if is possible. I think to help to integrate object with database. For example a object line to MySQL, I don't know about If already this functions is working or in developement. I think is hard to do, but... not impossible like another CAD Systems. So, thanks a lot! []s, Janse Romero |
Hi Ries!
I a beginner in this project, I don't know yet how it persiste a entity DB. But, What I thought was to create a handle inside the entity, and to refer it to a database with metadata information.
For ex.: I have a line, but this line is a wall with many characteristic and typical information, as well as White, made by stone and cement. Or We have a point, and this point means a pole of light, and his cost was $xxx,xx.
Did you get it ? In this case, no matter if the database is a GIS or not, and if is a MySQL or not, the important is to connect a entity to a data dictionary. How to ? Save a handle attribute in the entity and making a pluging read that one and to connect to some DB and show which meta data (on data dictionary) is that.
Sorry, If I couldn't be clear. Regards, Janse Romero On Tue, Feb 28, 2012 at 10:31 AM, R. van Twisk [via LibreCAD] <[hidden email]> wrote: Janse, |
Now, I understood you totally. So, I will study more the librecad codes.
And thanks a lot for your attention. []s, Janse Romero On Tue, Feb 28, 2012 at 11:20 AM, R. van Twisk [via LibreCAD] <[hidden email]> wrote: Janse, |
Hi Ries,
I still think support for native SVG file format as interesting, and I think we can add it to the idea list. I think you and rallaz understand CAD file formats better than I, so, it's up to your decision. Regards, Dongxu On Tue, Feb 28, 2012 at 8:31 AM, R. van Twisk [via LibreCAD] <[hidden email]> wrote: Janse, -- Dongxu Li, Ph.D. www.librecad.org |
Wow! Cool hardcode aditions... Thats the thing about open source...
Personaly, i think user base request of features should be considered more fondely, after all, theyre the ones to get to really use it.
2012/2/28 R. van Twisk [via LibreCAD] <[hidden email]> Dongxu, -- Fernando da Motta Hildebrand |
Hello everyone!! You may add to GSoC list , "ttf font support". I'm not specialist , and don't know what the need to do this. Valber src.lgg.ru 28.02.2012, 17:31, "R. van Twisk [via LibreCAD]" <[hidden email]>: Janse, |
Hello again! I converted the font to llf, but I don't understand how to fill it. screenshot http://src.lgg.ru/wp-content/uploads/2012/01/LibreCAD_ttf2lff.png our article about russian open gov.standard font : http://src.lgg.ru/2012/03/gost-type-%D0%B0-0/ Valber 29.02.2012, 00:28, "R. van Twisk [via LibreCAD]" <[hidden email]>: Valber, |
hi, the easiest way is to search the *.lff files installed by librecad, and copy your lff file there (with root/admin access). librecad should be able to use it. the same way works for lff in source code folder. thanks, dxli On Mar 9, 2012 12:21 PM, "hsd8 [via LibreCAD]" <[hidden email]> wrote:
The font and symbols look like outline, how can I get rid of the black hollows inside the letters? http://src.lgg.ru/wp-content/uploads/2012/01/LibreCAD_ttf2lff.png 09.03.2012, 21:59, "dxli [via LibreCAD]" <[hidden email]>:
