Hatching "spline through points" object
oguz.py
Hello guys,
I was trying to create a 2D drawing of my tail light. I used the "Spline through points" feature and made sure not to leave any gaps at the endpoints. However, when I try to use the "Hatch" command on the closed spline, I get the message "Hatch created successfully. Total hatch area = 0," but nothing actually appears. How can I fix this?
Re: Hatching "spline through points" object
aman
Hello and welocme!
Hatches can be a pain with complex items. It's been a while when used last. My solution was to enlarge the target so much, that quite often found a leaking corner.
Might also help if you devide the item with help lines.  Do a new layer for them, so you can disable it when you are ready.
