Hello everyone
1 message Options
Hello everyone
GuadalupeSullivan
Salomon Quest 4D 3 GTX Review: What Make It So Popular?
Salomon is a reputable brand, and Quest 4D is its popular hiking boots lineup.
Recently, the manufacturer has introduced the new version, Quest 4D 3 GTX, in an effort to carry the torch from its predecessors. Read on to find out if this release can live up to customers' expectations.
➤➤➤ Check My Source: Top Rated Hiking Boots
Comfort
When you put on the Quest 4D 3 GTX, you will now that it's a serious effort by Salomon. The firm lacing system and high collar hold your ankle and entire foot tightly in place. But you also have comfort thanks to the padding along the tongue and around your ankle.
When buying it, the Quest 4D 3 is so stiff out of the box, so we do not recommend you use it immediately for long trips. But after a break-in time, maybe just a few short hikes, you will feel it fit like a glove after loosening up enough.
Traction
The Quest 4D 3 and previous models in its lineup looks almost the same when you put them side by side upright. But if you flip all of them over, you will notice the redesigned outsole.
The stiffer rubber and wave-like look are no more. It now instead has soft Contagrip rubber and better spacing, helping you avoid picking up mud.
If you have bought several pairs of Quest 4D, you won't have any significant complaints about the traction. This newer version has more bite during steep areas, especially wet surfaces. The reason behind this is the pliable rubber.
Support and Stability
If you need a reason to upgrade from your lightweight hiking shoes or boots, then consider the stable feel of the Quest 4D 3 GTX. Its collar is higher than other typical mid-height models, such as the Keen Targhee III or the Merrell Moab 2.
But the main strong point setting it apart from those competing models is the solid support.
The semi-stiff construction can hold your feet firmly in place while not making you feel restrictive like any pair of mountaineering boots. It's also easy to use the Quest 4D 3 on rocky, loose ground, even under heavy loads.
All in all, if you just need a simple pair of hiking boots for a short-mileage, casual weekend trip, this incredible model from Salomon may be a bit overkill. But when you aim for more technical terrains, they are an ideal choice.
Waterproofing
With the Gore-Tex liners, it has no trouble keeping water away from your feet, making it one of The Best Hiking Boots . Unless you have significant missteps while crossing marshy off trails, which can pour water over the top, your feet will remain dry all the time.
Breathability
You should have any big issue with its breathability.
Even with premium membranes, manufacturers sometimes can't find a way to make your feet totally cool. But combining the quick-drying upper and a pair of high-quality hiking socks, you will have a well-ventilated experience considering they are waterproof boots.
This membrane will also bring decent warmth in the winter, which help to keep you comfortable while hiking or snowshoeing in low temperature.
Pros and Cons
Pros
  • Great comfort and support even under heavy loads on rugged terrain
  • Good grip even on muddy trails
  • Fantastic lacing system to lock your feet firmly on long descents and climbs
Cons
  • A bit overkill, heavy for easy, casual trails
  • Only have Gore-Tex version
  • Run warm in summer
Our Verdict
The Salomon Quest 4D 3 GTX is one of the  Best Rated Hiking Boots on the market. If you want a serious companion for your extended trips, consider it to have the best comfort and support along the trails.
