Hi, with the "List entities" plugin you could see some of the info you ask for:
Click on Plugins->List entities, select the entities you want the info, then hit Enter
alternatively, first select anything you want info, then click on Plugins->List entities, then hit Enter
Then copy/paste the output to a file, this is not automated, and maybe there are info you don't need, see for example the ouput of a circle:
n 4: CIRCLE
Layer: 0
Color: BYLAYER
Line type: BYLAYER
Line thickness: BYLAYER
center point: X=20.0000 Y=110.2500
radius: 23.9505
circumference: 150.4852
area: 1802.0961
HTH
Pere
