Hi from Hull in the UK
Gixxer
HI all, my name is Ricky, and I have recently installed LibreCAD 2 on my Linux computer.  Been using it for 2 days now, and I am impressed.
I recently bought a copy of the original (1940's) works drawing of the Union Pacific "Big Boy" locomotive, with the aim of drawing up a set of plans for an "O" gauge live steam model, and also the same for 2-1/2" gauge.  So far I have spent about 10 hours on drawing one of the driving wheels in full size, and in "O" gauge. And learning how to use the software as I go along :-)
Only found a couple of problems so far, On dimensions, I'd like to be able to adjust how far away the text is from the dimension line, but can't see an option for that.  Also, I can reduce the full size drawing to O gauge size by changing the measurement units from inches to millimetres, them scaling the drawing down by approximately half, but all the lines and text comes out too thick, so I'll have to have a think again on that.  Otherwise, great bit of kit.  I'm looking forqward to spending the next year or so drawing out the loco in model size, then another 3 or 4 years building it, lol
Cheers
Ricky
Re: Hi from Hull in the UK
Have a look at main menu:
Edit -> Current Drawing Preferences -> Dimensions
Play "with dimension line gap" and "general Factor", particularly for the two issues mentioned.
Cheers
Ricky
Gixxer
Hi dxli,
Thanks, the "dimension line gap" was the one that controlled the text distance from the measurement line, so that is sorted.  I am playing around with the other settings to resolve the other issue, which I'm sure with a bit of experimenting I will figure out.  Thanks for your help :-)
Cheers
Ricky
