Thanks dellus
I have also found a work around. If all hatches are done in a separate layer to the outline then it is much easier to separate hatch from the poly-line. If I hide the poly-line layer, then delete the hatch, when I unhide the poly-line layer the poly-line outline remains.
I was struggling with a 'solid fill' hatch but have subsequently discovered that if a typical cross hatch consisting of lines is used, then by zooming in and selecting one line of the hatch pattern and deleting that, the outline remains.
Many thanks again for your help, it inspired me to play around with it further.
Best regards
