I cannot figure out how to find the radius of an arc tangent to to a line. For example, suppose I draw arc tangent to a line and specify that the arc 9.527 degrees.
If I adjust the radius of the arc to fit some other constraint using mouse to drag the arc until it fits, can I then use something like the dimension command to determine the radius of the arc?
Thanks
