		Several ways:
  easiest to me:
  1, draw a circle of by (point, radius) at new position ( 28.915,21.367 ). the radius is not important here, using 1 or 5 doesn't matter;
  2, select the line;
  3, enable snap to center only, disable other snap options;
  4, click and hold on the point you want to move, which is shown with color now ( 29.341,20.869 ); drag it to the new position by snap point ( ( 28.915,21.367 ), release mouse;
  5, use selection pointer or Ctl-K to unselect the line.
  6, select the circle drawn in step 1, delete it by Modify->Delete selected (or Del key from keyboard).
  another general way is by Modify->Properties
