How to change the color of an existed entity ?
Johnson
My dxf is consisted by two entity.
one is a simple line which color is white
another is a special group entity (which is inserted by "Insert"),the color of this group is white
I want to change color of line to red .
and change the color of group to blue.
BTW, the two entity lies on same layer currently .
How can I do that ?
Thanks very much . Welcome your idea sincerely.
Re: How to change the color of an existed entity ?
Use Main menu:
Modify-> Attributes
Re: Re: How to change the color of an existed entity ?
Johnson
it doesn't work if the entity is a block (which is inserted ). :(
wingame82
Date: 2012-12-27 11:23
Subject: Re: How to change the color of an existed entity ?
Use Main menu:
Modify-> Attributes
http://forum.librecad.org/How-to-change-the-color-of-an-existed-entity-tp5707348p5707356.html
To unsubscribe from How to change the color of an existed entity ?, click here.
For a block, you should select the block in the block widget.
Use the button "Edit the active block in a separate window" to edit the block.
Then, you can change the attributes there.
All copies of the block will show the change.
