How to insert a block relative to another block
8 messages Options
txtinman
I cannot figure out how to insert a block relative to another block or another entity. Can someone help?
Mike White
Re: How to insert a block relative to another block
sp1der
txtinman
That link does not take me to your post. I did not find a post from you on this subject.
Mike White
sp1der
 Mike
I see what you mean, not sure whats up with the link anyway see my other post; "cannot open a new folder in Library browser"
Hope this helps
txtinman
Having to explode the block to set the zero point will get tiresome if you have many instances, but I will give it a try. Thanks.
Mike White
sp1der
Yes I agree -it would get very tiresome!
It needs changing!
txtinman
My work around was to put some temporary points or lines in the locations and then copy or insert the block at those locations. I would then delete the temporary points. It's not perfect, but it works.
Mike White
sp1der
Yes absolutely, use whatever helps to get the job done! Auxiliary constuction lines, points and other references are in my opinion an essential and necessary part of any drafting process.
For me I tend to set up a different layer called construction - with a different colour and work on this layer for construction lines etc. then when I`m done just "turn off" the layer.
