How to reposition your origin?
7 messages Options
Lloyd Knopp
Trying to reset my origin x0 y0 to a different position
Re: How to reposition your origin?
There is no special function to reposition absolute zero. You have to "select all" and move that from the desired point (specify reference point) to 0,0 (specify target point).
mpuech
Ok, but how can I do "Select all".
With Ctrl+A the function Tools > Modify stops and I can't select a rectangle with the mouse.
Regards
Do the selection first and then call the move/copy command.
sand1024
In reply to this post by Lloyd Knopp
This functionality so far is available in 2.2.2 branch (dev alpha), and not yet available in production versions (2.2.1 and earlier).
There it is possible to specify the user coordinates system  (origin position and rotation) (as described there - https://github.com/LibreCAD/LibreCAD/pull/2032). Probably that is what you're looking for.
mpuech
Yes, it's Ok.
Thanks
mpuech
It will be fine. I'll wait.
Thanks
