The options can be input in the option area. Try to search around for it (yes, it's a bad design, should be fixed in the upcoming 2.1 version).
BaziJoe wrote
I am using LibreCAD 2.0.7.
As I see the Modify->Offset feature doesn't give any possibility to set the offset distance.
(The tooltip on the toolbar says: "Experimental Feature, work in progress.")
Is there any way to set the offset distance?
