I can't dimension correctly
4 messages Options Options
kayalif
Greetings everyone!
I made drawing unit as centimeter and draw a horizontal line with entering 90 and a circle with radius 90.When I dimension horizontal line that shows just 9 not 90.I also used radial dimension and that is also 9.
so I changed length factor to 10 .Now I have my 90 on horizontal dimension but now I have 900 as radial dimension.
Am I doing anything wrong?
Version: 2.2.2.3-alpha<br/>Compiler: Microsoft Visual C++<br/>Compiled on: Jun  5 2025<br/>Qt Version: 6.9.1<br/>Boost Version: 1.87.0
System: Windows 10 Version 22H2
Re: I can't dimension correctly
Could you share a minimum dxf file with this issue?
kayalif
This post was updated on Jun 12, 2025; 6:38am.
sand1024
oh, great, thank you for reporting.
General dimensions support will be expanded soon (this is under development) - so it's good to check these issues too.
