Did some more testing.
The confusions only arise with layers having the same name.
It appears I have mistakenly called Layer '0' the construction layer.
Thanks for the reference to the drafting manual, another level of knowledge gained
My approach is to have nothing in layer '0' when importing, and to manage the layer names in the source and destination files.
If combining layer content is desired, the same name works fine.
If it is desired not to combine content, just re-name either the source or destination layers.
Then importing as a block and exploding all works fine, and no confusions.
Without exploding, Layer 0 seems to contain all the content.
Partial exploding with layers turned off is an area of exploration yet.
With an ordinary drawing, the insertion point when importing is the origin (0,0).
Not sure how to handle arbitrary insertion points.
John.
