Import from ms paint?
Johndom
Hi Guys. I have a few sketches I'd like to import from ms paint. Is there anyway I can do that? I tried importing bmp & png files, but not happening.
Warm Regards
John
Re: Import from ms paint?
Nothing happening? File - Import - Insert Image  should work for bmp and png files. You have to select an existing saved file. Then a rectangle representing the image appears. At the tab above the screen you can set angle, size factor or dpi. Drop the image at the desired place with left mouse click. Copy and paste from an external program like ms paint doesn't work.
