L.C. 2.1.2 on Lubuntu 18.04.2.
Generally works well and I am very pleased with it.
But, handling imported images on Layers is perplexing, and often frustrating.
Scaling and rotating seem unreliable, needing a couple of attempts to get the desired result.
The worst aspect happens when I make another layer and draw lines in the new layer.
The image often changes its Layer property and joins previous lines in previously allocated Layers.
Then, it is impossible to separate the lines from the image.
As I am trying to do parts drawings of an item only available as an assembled JPG image, many of the lines are drawn entirely within the image.
Not sure if this behaviour is a bug, or my lack of understanding.
Am I going about this the wrong way ?
Suggestions ?
John (in bushfire ravaged Sydney).
