Improvement to locating font directories
bgoodr
The default location of things like fonts needs to be relative to wherever the librecad executable is located. This is for local installs versus in /usr/bin.  This is in the use case of when you are building from source.
I have hacked my local sources to effect this by storing the fonts and other runtime directories in ../share relative to the bin directory, which is fairly standard fare.
Here is the patch:
diff --git a/librecad/src/lib/engine/rs_system.cpp b/librecad/src/lib/engine/rs_system.cpp
index 8fa40f8..15d5ce9 100644
--- a/librecad/src/lib/engine/rs_system.cpp
+++ b/librecad/src/lib/engine/rs_system.cpp
@@ -536,6 +536,10 @@ QStringList RS_System::getDirectoryList(const QString& _subDirectory) {
+        // share directory relative to the bin directory in the installation directory:
+        QFileInfo fileinfo(QCoreApplication::applicationDirPath());
+        QString finalDir(fileinfo.dir().path() + "/share/" + appDirName + "/" + subDirectory);
+        dirList.append(finalDir);
         // Ubuntu
         dirList.append("/usr/share/doc/" + appDirName + "/" + subDirectory);
Re: Improvement to locating font directories
Hi bgoodr,
wonderful feature!
Is it possible to add searching list for various case of building shadowed or not. I'm not sure about in-place building in source folder, for example, in linux/macx/mingw
qmake librecad.pro
make
the binary is unix/librecad. running from there should be supported auto.
Regards,
Dongxu
On Sat, Jun 16, 2012 at 2:04 AM, bgoodr [via LibreCAD] <[hidden email]> wrote:
Here is the patch:
         // Ubuntu
http://forum.librecad.org/Improvement-to-locating-font-directories-tp5706774.html
Dongxu Li, Ph.D.
www.librecad.org
bgoodr
Thanks very much, Dongxu!
Could you clarify what you mean by "building shadowed"?  I've not
heard that phrase before, but perhaps you mean path search
functionality that is similar the goal underlying my LibreCAD source
patch (see "<bg>" below).
That patch I posted is not checked into Git as of right now (Sat Jun
16 06:29:38 PDT 2012).  I am holding back for two reasons (a) I would
like to receive some feedback about whether or not the change is a
good one, and (b) I do not yet know what the process is for obtaining
approval to check into Git and into what branch. I should have
clarified that in my original post.
Allow me to elaborate in detail what my change does so that we can
decide if it is a good one, or if it needs further improvement, before
requesting checkin (For the record, see the references section
detailing my current install of Debian Linux in [1]):
After building and installing LibreCAD and copying the files into a
Autoconf-like directory structure [2], I invoked the tool and tried to
add text objects, but no such object was added (and the font list
pulldown did not show any font names at all).  I debugged the problem
and discovered that RS_System::getDirectoryList hardcodes paths to
/usr for the tool-supplied fonts, hatches, plugins, etc. To fix the
directory lookup logic so that the fonts and other files supplied with
the LibreCAD sources are properly found at runtime, I added the code
shown marked as "<bg>" below:
|     // Unix home directory, it's old style but some people might have stuff there.
|     dirList.append(getHomeDir() + "/." + appDirName + "/" + subDirectory);
|         //local (application) directory has priority over other dirs:
|         if (!appDir.isEmpty() && appDir!="/" && appDir!=getHomeDir()) {
|                 if( appDir != getCurrentDir() && subDirectory != QString("plugins")) {// 17 Aug, 2011, Dongxu Li, do not look for plugins in the current folder, we should install plugins to system or ~/.LibreCAD/plugins/
|             dirList.append(appDir + "/" + subDirectory);
|         <bg> // share directory relative to the bin directory in the installation directory:
|         <bg> QFileInfo fileinfo(QCoreApplication::applicationDirPath());
|         <bg> QString finalDir(fileinfo.dir().path() + "/share/" + appDirName + "/" + subDirectory);
|         <bg> dirList.append(finalDir);
|         // Ubuntu
|         // Redhat style:
|         dirList.append("/usr/share/" + appDirName + "/" + subDirectory);
Here is what I believe the "<bg>" code snippet does:
 1. Get the runtime directory of where librecad is installed
    (QCoreApplication::applicationDirPath()), which should be a "bin"
    directory.
 2. Find the parent directory of that "bin" directory (fileinfo.dir().path()).
 3. Construct the file name via "<parent_dir>/share/<appDirName>/<subDirectory>".
The effects of that code change should be:
 1. It doesn't matter where the application lives. It could be in
    /usr/bin/librecad, could be in
    /home/joeblo/install/something_os_specific_here/bin/librecad,
    etc., which allows for locally built installations.
 2. It should not interfere with users putting their own additions
    relative to their own $HOME/ directory as the code above in "old
    style but some people might have stuff there" will supercede the
    "<bg>" change.
 3. It should not interfere with what Debian package maintainers are
    doing today in their build infrastructure as it conforms nicely
    with an expected directory structure [2].
If we find the "<bg>" change acceptable as is, then I also believe we
should delete the "Redhat style" code shown below: The "<bg>" code
yeilds the same results when the "bin" directory is "/usr/bin":
|         // Redhat style:
Do you think that a good enough fix for this use case? If so, then
I'll need to find out what the checkin process is and formally submit
the change.
Thanks,
bg
Detailed reference material that most folks probably can ignore:
[1] My current system info and state:
    My Debian system /etc/apt/sources.list file contains the following:
    | # deb cdrom:[Debian GNU/Linux wheezy-DI-a1 _Wheezy_ - Official Snapshot amd64 NETINST Binary-1 20120512-00:39]/ wheezy main
    | #deb cdrom:[Debian GNU/Linux wheezy-DI-a1 _Wheezy_ - Official Snapshot amd64 NETINST Binary-1 20120512-00:39]/ wheezy main
    | deb http://ftp.us.debian.org/debian/ wheezy main
    | deb-src http://ftp.us.debian.org/debian/ wheezy main
    | deb http://security.debian.org/ wheezy/updates main
    | deb-src http://security.debian.org/ wheezy/updates main
    The /proc/version on this system shows:
    | Linux version 3.2.0-2-amd64 (Debian 3.2.17-1) (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-5) ) #1 SMP Sat May 12 23:08:28 UTC 2012
    The /etc/debian_version on this system shows:
    | wheezy/sid
    Executing:
    | apt-cache show librecad
    shows:
    | Package: librecad
    | Version: 1.0.2+nolibs-1
    | Installed-Size: 4116
    | Maintainer: Debian Science Maintainers <debian-science-maintainers@lists.alioth.debian.org>
    | Architecture: amd64
    | Depends: libc6 (>= 2.4), libdxflib-2.2.0.0 (>= 2.2.0.0), libgcc1 (>= 1:4.1.1), libmuparser2 (>= 2.1.0), libqt4-help (>= 4:4.5.3), libqt4-qt3support (>= 4:4.5.3), libqt4-sql (>= 4:4.5.3), libqtcore4 (>= 4:4.7.0~beta1), libqtgui4 (>= 4:4.6.1), libstdc++6 (>= 4.4.0), librecad-data (= 1.0.2+nolibs-1), libqt4-sql-sqlite
    | Description-en: Computer-aided design (CAD) system
    |  LibreCAD is an application for computer aided design (CAD) in two
    |  dimensions (2D). With LibreCAD you can create technical drawings such as
    |  plans for buildings, interiors, mechanical parts or schematics and
    |  diagrams.
    | Homepage: http://www.librecad.org/
    | Description-md5: d9135c95b7b340a7d52e6f02c873080e
    | Tag: interface::x11, role::program, scope::application, uitoolkit::qt,
    |  x11::application
    | Section: graphics
    | Priority: optional
    | Filename: pool/main/libr/librecad/librecad_1.0.2+nolibs-1_amd64.deb
    | Size: 2081116
    | MD5sum: ee732b724508b0439e25412924bed946
    | SHA1: 9327c71b2f15f86558937a64d6d1e6caaf258d25
    | SHA256: 329cdadec72dae3aa3b4e8d3a03d98af94731e15919447aa9a6862f70c1b7479
    Executing:
    | dpkg --list librecad\*
    shows:
    | No packages found matching librecad*.
    just to show that I am not currently running a mixed environment
    (e.g., librecad installed in both /usr/bin and also installed into my
    local built-from-source directory).
    The version of LibreCad sources as revealed by the Help/About menu
    shows (grrr! librecad --help is not implemented <sigh>):
    | Version: master
    | SCM Revision: 2.0.0alpha3-158-g0a6f3a0
[2] I reverse-engineered what the Debian package maintainers did when
    constructing the librecad Debian package, and then used that info
    to make guesses about how to lay out my locally built installation
    of LibreCAD in my own build script. This implements what should (IMO)
    have been done in LibreCAD's "make install" logic. Below,
    $INSTALL_DIR is identical to GNU Autoconf's "prefix" concept
    described at:
    http://www.gnu.org/prep/standards/html_node/Directory-Variables.html):
    | PrintRun ()
    |    echo
    |    echo "COMMAND: $*"
    |    set -e
    |    set +e
    | PrintRun make
    | # "make install" does nothing as of Thu Jun 14 06:59:30 PDT 2012:
    | ### PrintRun make install
    | # So I have to handle that myself here:
    | # I downloaded and examined the Debian source package at
    | # http://packages.debian.org/source/sid/librecad to see what they do
    | # to install it. Inside ~/librecad_1.0.2+nolibs-1.debian.tar.gz we see
    | # the debian/librecad-data.install file which contains:
    | #    support/fonts /usr/share/librecad
    | #    unix/resources/library /usr/share/librecad
    | #    unix/resources/patterns /usr/share/librecad
    | #    unix/resources/qm /usr/share/librecad
    | # And inside ~/librecad_1.0.2+nolibs-1.debian.tar.gz we see the
    | # debian/librecad.install file which contains:
    | #    unix/librecad /usr/bin
    | #    debian/librecad.xpm /usr/share/pixmaps
    | #    debian/librecad.png /usr/share/icons/hicolor/48x48/apps/
    | #    debian/librecad.svg /usr/share/icons/hicolor/scalable/apps/
    | #    debian/librecad.desktop /usr/share/applications
    | # So simulate most/all of that:
    | MyInstall ()
    |     if [ -d "$1" ]
    |     then
    |         PrintRun mkdir -p "$2"
    |     fi
    |     PrintRun rsync -a -v -u --progress "$1" "$2"
    | MyInstall librecad/support/fonts/ $INSTALL_DIR/share/librecad/fonts/
    | MyInstall unix/resources/library/ $INSTALL_DIR/share/librecad/library/
    | MyInstall unix/resources/patterns/ $INSTALL_DIR/share/librecad/patterns/
    | MyInstall unix/resources/qm/ $INSTALL_DIR/share/librecad/qm/
    | MyInstall unix/librecad $INSTALL_DIR/bin/librecad
    | # And I added this because I am guessing the .so's are plugins:
    | MyInstall unix/resources/plugins/ $INSTALL_DIR/share/librecad/plugins/
    | # And I added this because it was an executable. Seems like Debian excluded it??
    | MyInstall unix/ttf2lff $INSTALL_DIR/bin/ttf2lff
Hi bgoodr,
The patch is quite good.
If you have a github repository, you can simply send in pull request to the main tree: LibreCAD/LibreCAD.git. If you still want me to apply the patch manually, please let me know.
I hope we can review the folder handling at this time, to make sure it works without copying over files manually, for example,
Best Regards,
Dongxu
On Sat, Jun 16, 2012 at 10:40 AM, bgoodr [via LibreCAD] <[hidden email]> wrote:
|         // Ubuntu
|         // Redhat style:
    directory.
    "<bg>" change.
|         // Redhat style:
the change.
Thanks,
bg
    | # deb cdrom:[Debian GNU/Linux wheezy-DI-a1 _Wheezy_ - Official Snapshot amd64 NETINST Binary-<a href="tel:1%2020120512-00" value="+12012051200" target="_blank">1 20120512-00:39]/ wheezy main
    | #deb cdrom:[Debian GNU/Linux wheezy-DI-a1 _Wheezy_ - Official Snapshot amd64 NETINST Binary-<a href="tel:1%2020120512-00" value="+12012051200" target="_blank">1 20120512-00:39]/ wheezy main
    | Linux version 3.2.0-2-amd64 (Debian 3.2.17-1) ([hidden email]) (gcc version 4.6.3 (Debian 4.6.3-5) ) #1 SMP Sat May 12 23:08:28 UTC 2012
    | wheezy/sid
    Executing:
    shows:
    | Package: librecad
    | Maintainer: Debian Science Maintainers <[hidden email]>
    |  diagrams.
    |  x11::application
    | Section: graphics
    | Size: 2081116
    Executing:
    shows:
    | Version: master
    described at:
    | PrintRun ()
    |    echo
    |    set -e
    |    set +e
    | PrintRun make
    | MyInstall ()
    |     if [ -d "$1" ]
    |     then
    |     fi
http://forum.librecad.org/Improvement-to-locating-font-directories-tp5706774p5706777.html
Dongxu Li, Ph.D.
www.librecad.org
bgoodr
Thanks for the reference for the definition of "Shadow build". That is not what my change will provide, however, I do see the value in the shadow build concept. I will read up on forking and pulling and give it a try.
I will examine http://sourceforge.net/tracker/?func=detail&aid=3462980&group_id=342582&atid=1433847 to see what I can make sense of it.
bg
