Hello Claude,
I'm going to have to make an assumption that you have successfully created a block and it appears in your 'Block List' window.
If that is correct, then you select the block from the Block List window and click the 'Insert the active block' icon
. You will then be prompted to 'Specify the reference point'. Click the reference point on your drawing and you block should appear. You can continue to insert blocks until you press [Esc] or right mouse button.
