Installing on Linux (after building)
5 messages Options Options
Eric S
I've successfully built LibreCAD (current "master").  My question is about how to install it.  Normally I'd do "sudo make install" at this point.  That exists, and "succeeds" in the limited sense that it doesn't produce any errors, but it doesn't appear to do anything.
All the instructions I've been able to find just say "the generated executable is at ./unix/librecad" or variants thereof -- no mention of an install procedure.  (Pages consulted:
  - https://wiki.librecad.org/index.php?title=Build_from_source
  - https://github.com/LibreCAD/LibreCAD/wiki/Build-from-source#generic-unix
Is there a recommended way to install globally on the system?
Re: Installing on Linux (after building)
fa201
You should check this proceedure : https://librecad.readthedocs.io/en/latest/appx/build.html#building-on-linux
It was checked on both Debian and Ubuntu.
Fabrice
Eric S
The Building on Linux section ends with:
If the build is successful an executable is created, ~/dev/LibreCAD-master/unix/librecad, and LibreCAD can be launched by typing:
$ ./unix/librecad &
No mention of a post-build install procedure there either.
Edited to add: To be clear, I have built it, and have run it via "./unix/librecad &" as described.  But running it out of a build directory buried deep in my open-source-projects tree is less than ideal.
fa201
Is an alias acceptable ? Opening a terminal and type a command is not much of a pain...
Fabrice
Gary S
In reply to this post by Eric S
