LIBRECAD ISSUE WITH QT
10 messages Options
IRD
IRD
I am new on Librecad and I would like to contribute on its development with Qt.
However, when I compile the source code with Qt 5 there is no issue but it doesn't open Librecad at the end of teh process.
Is-it normal?
Many thanks,
IRD
Re: LIBRECAD ISSUE WITH QT
hi,
which os?
if you are building by qt-Creator, you need to configure the "Run" option to librecad instead of ttf2lff.
thanks,
Dongxu
On 2013-11-28 1:44 PM, "IRD [via LibreCAD]" <[hidden email]> wrote:
Is-it normal?
Many thanks,
IRD
http://forum.librecad.org/LIBRECAD-ISSUE-WITH-QT-tp5709218.html
IRD
IRD
I work with Ubuntu 13.10.
What do I have to change in the Run option of Qt?
hi,
for qt creator: http://qt-project.org/doc/qtcreator-2.8/creator-run-settings.html
it is easy by command line:
qmake -r
make -j4
unix/librecad
thanks,
Dongxu
http://forum.librecad.org/LIBRECAD-ISSUE-WITH-QT-tp5709218p5709221.html
IRD
IRD
I have tried your answer on the terminal.
I have the following errors even if I am able not to open the project:
 RS_DEBUG::setLevel(3)
RS_DEBUG: Critical
RS_DEBUG: Errors
RS_DEBUG: Warnings
Erreurs au lancement en ligne de commande :
Plugin verification data mismatch in '/usr/lib/librecad/libalign.so'
Plugin verification data mismatch in '/usr/lib/librecad/libasciifile.so
Plugin verification data mismatch in '/usr/lib/librecad/libimportshp.so'
Plugin verification data mismatch in '/usr/lib/librecad/liblist.so'
Plugin verification data mismatch in '/usr/lib/librecad/libsameprop.so'
Plugin verification data mismatch in '/usr/lib/librecad/libsample.so'
Does it mean that I have to import additional libraries?
Furthermore, I have failed to set up Qt : comilation ends without opening LibreCad.
remove the librecad package from ubuntu daily build:
sudo apt-get remove librecad
we have disabled building of plugins by default.
IRD
IRD
Does it mean that I can download a new package to continue my project?
Could it be due to the fact that I am working with Qt 5.1 (I Will have to switch to Qt 5.2 for bluetooth issues)?
no.
because you have old binary plugins in /usr/lib/librecad/ from the ubuntu librecad package.
http://forum.librecad.org/LIBRECAD-ISSUE-WITH-QT-tp5709218p5709225.html
Dongxu Li, Ph.D.
www.librecad.org
IRD
IRD
I have applied your line of command.
However, even if I have not modified the qc_applicationwindow.cpp I have now the following bug :
librecad/src/main/qc_applicationwindow.cpp:314: error: cannot declare variable 'pligundoc' to be of abstract type 'Doc_plugin_interface'
     Doc_plugin_interface pligundoc(currdoc, w->getGraphicView(), this);
What's wrong?
NB: Extract from the qc_applicationwindow.cpp
 * Execute the plugin.
void QC_ApplicationWindow::execPlug() {
    QAction *action = qobject_cast<QAction *>(sender());
    QC_PluginInterface *plugin = qobject_cast<QC_PluginInterface *>(action->parent());
//get actual drawing
    QC_MDIWindow* w = getMDIWindow();
    RS_Document* currdoc = w->getDocument();
//create document interface instance
//execute plugin
    plugin->execComm(&pligundoc, this, action->data().toString());
//TODO call update view
w->getGraphicView()->redraw();
IRD
IRD
I have solved this issue.
In fact the problem come from the frame of sameprop.cpp.
Indeed, it uses Qvariant and therefore some types have to be defined as Q_DECLARE_METATYPE()
However I am unabled to identify what have to declare as Q_METATYPE.
Anyone has an idea?
Thanks
Extract from sameprop.cpp
    QHash<int, QVariant> data, moddata;
    QList<Plug_Entity *> obj;
    QVariant lay, col, ltype, lwidth;
    lay = data.value(DPI::LAYER);
    col = data.value(DPI::COLOR);
    ltype = data.value(DPI::LTYPE);
    lwidth = data.value(DPI::LWIDTH);
