LibreCAD dockwidgets
3 messages Options Options
usuario
I'm using a translator.
Thank you very much for your work on LibreCAD, I would like to report the following behavior with the "Dockwidgets", I don't know if it has already been reported, if so, I apologize.
Best regards.
https://www.youtube.com/watch?v=xJo2SdSGPrc
Version: 2.2.1_rc2-1-g4cd3b138
Compiler: GNU GCC 12.2.0
Compiled on: May 13 2024
Qt Version: 5.15.2
Boost Version: 1.75.0
If you need I can try in Debian [1].
1. https://www.debian.org/
Re: LibreCAD dockwidgets
Thanks!
I was not aware of this issue.
sand1024
In reply to this post by usuario
Yes, it might be that the vertical size of toolbar is not enough to place all widgets properly.
I've noticed similar issue before and added and option to handle this.
Please check Option->Widget options->Left toolbar columns setting
There you can adjust how many columns should be used to draw actions so they will fit nicely for your screen and resolution.
While potentially it is possible to support more intelligent dynamic adjusting of left toolbar actions based on window size, I suppose it will be rather overkill - at least by my experience, one time adjustment of columns count is enough.
