Librerie DXF
4 messages Options Options
Librerie DXF
onofriotulone
1 post
Buongiorno,
ho provato ad importare alcune librerie al path "C:\Program Files (x86)\LibreCAD\resources\library" e tutto funziona però non riesco a trovare librerie per incidentistica stradale, quindi motocicli, autocarri, automobili etc.
I file ho capito debbono essere in formato DXF
Qualcuno sa dove reperirli?
grazie comunque
Saluti
Re: Librerie DXF
duncan.lithgow
Try searching for "free dwg blocks" or "free autocad blocks" and you will find many objects in DWG format. Here is one site I found: https://dwgmodels.com/
You can then use the ODA Converter to convert the file from .dwg to .dxf. Choose .dxf 2013 version or earlier
https://www.opendesign.com/guestfiles/oda_file_converter
I hope that helps.
Thank you google translate!
IRC: duncan-nz
Twitter: @BIM_DK
Re: Librerie DXF
duncan.lithgow
There is also this collection in the .dxf format a LibreCAD user has started. Perhaps you can help it grow?
https://github.com/GSStnb/dxfBlocks
IRC: duncan-nz
Twitter: @BIM_DK
Re: Librerie DXF
Gubbeb i Kalmar
In reply to this post by duncan.lithgow
Thanks for your tip.
this did not go well
I am running Ubuntu 18.04.5
This worked better:
https://cloudconvert.com/dwg-to-dxf
