Line Dividing
3 messages Options Options
Line Dividing
sladden
1 post
Is there a way to draw a line of any length in any direction. Then divide the line into equal sections?
That way I can draw an 'L' out of 2 lines. Then divide the vertical into 13 equal spaces and the horizontal into 25 equal spaces (or any other spaces, of my choice). Then create a grid to draw a chosen shape into.
I use this ability in other CAD software for the purpose of drawing shapes. To print and glue to a piece of wood, to cut out using a jig-saw, band-saw or scroll-saw.
I can then take the original drawn shape and change the vertical and/or horizontal scales to use in different proportions on different sized pieces of wood.
Re: Line Dividing
One way to do it is by copy/move in menu: Modify -> Copy/Modify
When the dialog box shows up, there is a checkbox "multiple copies"
You can draw a small "cell" to be duplicated. copy this cell in one direction for multiple copies, and copy the generated "band" in the perpendicular direction, you get a grid.
Re: Line Dividing
Willem
In reply to this post by sladden
Hello Sladden,
1. Make a drawing of your “L”
2. Select Menu / Draw / Line / Parallel
3. In the commmandline, type the wanted distance between the lines (for example 20) and <Enter>
4. Move the cursor over one line in the drawing and a new line at a distance 20 mm will appear. Click to set the line.
5. Repeat moving the cursor and click for more lines.
Greetings,
Willem
