Lines not working ?
Lines not working ?
sparkymike
I am now getting used to the system, but halfway through a drawing, when I select lines, it does not work.
It is like line control is locked. I had this before with another drawing and same thing happened.
Mike.
Re: Lines not working ?
Maybe previous command wasn't finished properly. Try Esc Esc.
Or the layer is locked. The padlock symbol in the Layer List.
sparkymike
Thank you Dellus. I will check that out.
Is it possible to alter the dimensions to closer tolerances ?
Mike.
Play with settings in Options - Current Drawing Preferences - Units and Dimensions regarding Precision and Zeros.
