Lines thickness
Lines thickness
roberto fabbri
Hi All.
I'm Roberto.
I have a problem with the lines' thickness of a draw I've made.
It represents a sofa from 2 views, top and front.
In the beginning both the views had lines with different thickness.
I went on Widgtes>Dock Widgets>Levels list, I clicked on the last icon on the right, I choosed the level
and the top view was OK. Not the front one.
I realized I was in "draft mode", therefore I exited "draft mode" and re-selected the thickness, but nothing changed.
Whan I copied the front view I saw that Librecad firstly selected only the thick lines, despite later it copied all the front sofa. Maybe this can help?
I tried to upload an image, both with "insert image" and "upload a file", but i couldn't.
I don't know what else I can try.
Thank you very much in advance for all the help you can give me, guys.
Roberto
Re: Lines thickness
Maybe a layer accidentally is locked (black lock symbol in layer list). It can't be selected and copied then nor the line thickness changed.
Maybe line thickness has been defined directly in pen properties and not as by layer. Then changing pen thickness in layer attributes has no effect on them.
Best is to try again to upload the file. After having selected the file you have to press "Upload file" again, you may have missed that.
Re: Lines thickness
roberto fabbri
Hi Dellus.
I pressed "Upload file" after choosing it, actually, but they simply appeared the words here below...
The layer doesn't seem locked (the padlock picture is grey and not black).
I shouldn't know were to find the pen properties....
Best
Roberto
Re: Lines thickness
roberto fabbri
Ooopsss, it loaded.....
Re: Lines thickness
I meant to upload the dxf-file... Go to More... in the browser.
Select a line you want to change by clicking on it then go to Tools - Modify - Properties. What does it say? You can change the properties here.
These are the pen properties:
When being drawn lines get these properties.
Re: Lines thickness
roberto fabbri
Hi Dellus.
Thank you for your message.
As you can see here above I uploaded the message.
It was simply unusual for me to read those strange words as I clicked on "Upload", but the file was actually uploaded.
I solved the thickness problem redrawing the thick lines.
Thank you very much again for your help.
Warm regards
Roberto
