Sheets blank: often the reason is linewidth "By Layer" is set, where default is 0.00mm. Depending on printer often not printed at all, or very very faint. But as you say -
Preview blank: preview shows linewidth 0.00mm, so it must be something different. Maybe out of the sheet, or very small. Try the buttons "Fit to page" and "Center to page", also play with the scale setting.
- Cannot load file I made - from within the app: There have been complaints like this with Windows in the past, but I don't remember the abouts, what's the reason and how to fix it. You may have success with using File - Recent files.
-When opening file from Windows Explorer the help panel is missing: I have no explanation, you may try Options - Application Preferences - Defaults - Clear Settings - Layout or All, in case you have borked something.
